Fouling Points?
wubie317
Fouling Points?
Post by wubie317 »
Recently, it seems that I'm going through points faster than normal. I can only keep a good smooth idle for a few hundred miles before there's a dusty gunk on the contacts. Any thoughts on what it means? Is this a symptom of a bigger problem?
bradartigue
Re: Fouling Points?
Post by bradartigue »
(1) Do you have a ballast resistor? You need one if not. Some have an internal ballast (Bosch Blue), some do not (Marelli, FIAT OEM)
(2) Is there excessive play in the distributor shaft?
wubie317
Re: Fouling Points?
Post by wubie317 »
bradartigue wrote:(1) Do you have a ballast resistor? You need one if not. Some have an internal ballast (Bosch Blue), some do not (Marelli, FIAT OEM)
Since I don't know the answer to the ballast resistor question I'll assume I do not. ;) Should I simply get "Bosch blue" points? I've always just used the ones available at Autoricambi
Re: Fouling Points?
are you using a distributor cam lube?
bradartigue
Re: Fouling Points?
Well, you need to know. Find the part number of your distributor, test the output with a voltmeter.
wubie317
Re: Fouling Points?
Post by wubie317 »
OK, I ordered a ballast resistor from Bayless. Assuming I don't have one to replace (I've never noticed a thing that looks like what I got), where does it go? I do have a Marelli coil, and have changed to single point setup. Does anyone have a picture and/or installation instructions?
bradartigue
Re: Fouling Points?
wubie317 wrote:
bradartigue wrote:
wubie317 wrote: Since I don't know the answer to the ballast resistor question I'll assume I do not. ;) Should I simply get "Bosch blue" points? I've always just used the ones available at Autoricambi
Take the + lead on your coil and put it on the resistor, then the lead from the resistor and put it on the + terminal of the coil.
wubie317
Re: Fouling Points?
Post by wubie317 »
Abundance of caution...so it's in a loop to itself?
bradartigue
Re: Fouling Points?
I'll steal the image from the folks you bought it from:
In simple terms take the lead running to the positive lead on the coil and put it on the resistor's open terminal. Then take the lead from the resistor and put it on the coil.
12V >> ------ Ig Switch ---------- Resistor ------------ Coil
It will drop the load to the coil when starting and running, which makes the points last longer. I don't know if this will solve your specific problem, but if you have the Marelli coil and no resistor then you will have problems in general.
wubie317
Re: Fouling Points?
Post by wubie317 »
I get it now...Thanks!
