Hello,
does anybody tried to install the Lancia Thema Brakes with Discs on a 1980 Fiat 124 Spider?
I heard it will fit, but i don't have the parts to try, yet.
Best regards
Norbert
Lancia Thema 284mm (11,2")
- Your car is a: Fiat 124 Spider 2000 Cs0
Re: Lancia Thema 284mm (11,2")
Why do you want to put thoses?
Because the original brake isnt the best... and the Lancia Thema parts are cheap and available.
I put Vicks big brake kit with Wildwood calipers, Volumex MC and brake booster. And it still not the best... I plan to add the rear kit from Mark and hope for the best.
- divace73
you'll find the rotor hat height will be different and no doubt you will need to make to mounting brackets.
Also the MC may not be matched up with the caliper
Nothing is impossible, let us know how you go
Cheers David
see my >>You tube channel<<
First i will check if i can get this upgrade legal in Germany... then i start trying
I know the Fiat Uno Turbo Breaks will fit, but the parts are rare
