Double Relay Set
ralphcap
Double Relay Set
Post by ralphcap »
I have a 1981 FI 2000. Exactly where is the Double Relay Set located. Is it on the relay panel adjacent and to the left of the ECU? Everything I've read states it is "under the glove box" or "it is located near the ECU" I'm seeking more specific information.
spider2081
Patron 2024
Patron 2024
Re: Double Relay Set
Post by spider2081 »
It located on the relay panel mounted under the glove box. The panel is held in place by 2 phillips screws near the glove box hinges under the dash
4uall
Post by 4uall »
this might help :wink:
ralphcap
Post by ralphcap »
Wow! Thanks y'all. I continue to be an unending source of dumb questions!
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
ralphcap wrote:Wow! Thanks y'all. I continue to be an unending source of dumb questions!
Not even close, friend! My questions are far worse...
1979 Fiat 2000 "Luigi"
