Well I woke up yesterday and started Pesto and something didn't sound right. I brought him up to running temp and something was off about the idle, it was really low, barely maintaining 300rpm, and lumpy and seemed to be missing. Acceleration was extremely hesitant and lacking power so I checked the plugs and they seem alright, not great looking, but alright. I fiddle with the timing a bit and no change. So I did a compression test: #1=122, #2=103, #3=126, #4=115.
Any thoughts?
Pesto has a cold :~(
- 70spider
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
Re: Pesto has a cold :~(
check to see if you have spark at each plug. Just looking at the plug isn't enough. If you are still using a dizzy type ignition, pull each plug wire and see if it changes anything.
Vacuum leak? Jumped cam timing?
- 70spider
I checked the cam timing and everthing lines up. I'll get the spark tomorrow if I have time. By the way, is there suppose to be that much variance in the compression readings? Well thanks for the replies.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
- kilrwail
Check the ignition points gap. It can drift off after having been properly set.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- Your car is a: 1978 Spider
I recently had this issue. While the engine was running I started to disconnect plug wires:
-pulled number 1 and it quit, started up again
-pulled number 2 and it kept running with no change
-pulled number 3 and it quit, started up again
-pulled number 4 and it kept running with no change
I pulled the the plugs and they were dark, number 2 and 4 were wet with gas. It was running rich and fouling plugs to the point I was running on 2 or 3 cylinders.
I cleaned the plugs and verified spark. Once everything was buttoned back up again it ran well and the idle settled to around 900..
- bradartigue
The compression in #2 is low - but not low enough to stop from running. Sounds like a good old ignition problem, diagnose it before you go elsewhere, including checking that the dizzy hasn't slipped.
1970 124 Spider
http://www.artigue.com/fiat
- 70spider
Well I finally got some time to work on him. I took a shot and bought some plugs, even though I changed them less than 1,000 miles ago, and it did the trick. The old plugs were black with carbon, indicating a rich condition. When I got the 32/36 DFEV I change the primary idle jet to a smaller one but left the others unchanged. Should I change the others as well?
Thanks for all the suggestions.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
