Camshaft cover
Spidernord
Camshaft cover
Post by Spidernord »
]Hello
I have a Spider 2000 with a Abarth 130TC engine.
The normal "end cove" for the camshaft, is too little (this is on the inlet side).
Do someone know if there is different sizes on these covers?
131
Re: Camshaft cover
Post by 131 »
Spidernord wrote:]Hello
The 130tc had the ignition distributor on the end of the inlet cam, there probably isn't a cover to fit it if the distributor has been removed. You'll either have to make one or replace the cambox.
Mick.
djape1977
Re: Camshaft cover
Post by djape1977 »
too little in what way?
pic would help...
