header wraping and fan Pb
Re: header wraping and fan Pb
I've done the same. I bought some heat wrap for the hoses near the headers. No issues after 5 years..So Cal Mark wrote:wrap the stuff near the header, not the header itself
- v6spider
That's exactly it Mark.. But I have no over heating issues and I'm not wrapping anything.. Even the brakes are fine and the booster is a 1/4 away at one point.. I have wrapped the fuel lines and plan on wrapping or shielding the entire length of it.So Cal Mark wrote:wrap the stuff near the header, not the header itself
Cheers!
Rob
http://www.v6spider.com
I saw a new product at SEMA used for coating headers. It can be sprayed, brushed or dipped. With coating on both inside and out, temps 1" from the tube was 130F with the engine running. It will be available in December and I plan on stocking it
- v6spider
That's awesome yes I'm curious.. What's it called?So Cal Mark wrote:I saw a new product at SEMA used for coating headers. It can be sprayed, brushed or dipped. With coating on both inside and out, temps 1" from the tube was 130F with the engine running. It will be available in December and I plan on stocking it
Thanks!
Rob
