With IAP gone, I was wondering if anyone knows who sells rebuilt 1608 short blocks these days. Vick's lists a shortblock for the 1995 only, though they do list 1608 long blocks, but they are expensive. I might call them to see if they can do the 1608. I am assuming that the Vick motors should be OK, but from what I have read here, not everyone likes the pistons they use. I was wondering if anyone knows any other reputable vendors.
Reason I ask, is that I am about to buy a 1971 Spider with a very decent body but a cooked motor. I am pretty sure it ran without oil, as compression is low, power is nil and it sounds terrible, especially when under load, so I assume everything below the cylinder head is fried, pistons, rings and bearings. I did not know the motor was bad when I went out to look at it, the seller claimed it was fine, but I sure found out when I got there. As a result, I am picking it up for a very good price, but I was not really planning on a big project. I do not want to get into a total part-by-part rebuild of the original engine, for all I know I would need to replace all the internals anyway. I would rather hope to fine a decent complete engine, lightly used, and just swap it in. Used engines are listed out there, but it seems like a crapshoot to get a good one. Failing that I would like to get a rebuilt short block and reuse the original cylinder head, following a valve job, of course. That would be much more economical than a rebuilt long block for $5200... Ouch.
Who sells rebuilt 1608 short blocks?
- Your car is a: 1971 Sport Spider and 1979 Spider 2000
Re: Who sells rebuilt 1608 short blocks?
Where about's are you?
I have a 1600 sitting in my parts car you can have cheap. I'd re-build the thing before putting it in a car though.
I'm near Penticton BC and have a shop here with a hoist and engine lift you can use to get the thing out.
Chris
Chris
Thanks for your reply narfire, but I would have a ways to get to you from here in Connecticut! For all the major PITA it is to pull an engine and put it back, I would not want to waste this time on a motor that has seen its better days. I would want something pretty fresh, if not completely fresh, but I do not want to do a total teardown and rebuild myself to do it. I would probably die of old age before finishing... Anyway if I was to have someone do the rebuild for me, I already have the lump. Of course I could find out that the crank and rods are toast. The pistons probably are.
Scoop,
Get hold of Danny at Fun Imports. He is an excellent source for all of us and will be able to help you out.
http://www.funimported.com/
Holy smokes Exit, I just got off the phone with Danny, and he is awesome! I can't believe I did not know about him already, as I have had my 1979 for 5 years. Thanks so much for that tip!
