Good afternoon, All.
I need lot of help here. POs, and there were many, have made mods that I have no understanding of.
Here are some pis:
Overall Engine. Sorry for the lousy iPad pics...
"A" is the emmision?
"B" and "C" are sensors?
"D" is a performance part?
"F" has to do with heat?
"G" and "H" are just better pictures of the sensors. The longer wire is connected to the closer sensor and the shorter wire isn't connected at all.
Any help with the letters would be appreciated. I haven't taken pics of the serial numbers yet, but will.
Thanks and enjoy the weekend,
CCucchi
Need help Identifying what I have here
- Your car is a: 1979 Fiat 2000
1979 Fiat 2000 "Luigi"
Re: Need help Identifying what I have here
F seems to just be a simple fill and bleed T for the cooling system. It allows for easier flushing of the system.
Thanks, Rambo.Rambo wrote:F seems to just be a simple fill and bleed T for the cooling system. It allows for easier flushing of the system.
One down, a whole mess to go.
- courtenay
G and H look to be the senders for the temperature gauge. The one nearest the radiator (without the wire) is the one that "pegs" the needle. The other is the one that controls the gauge itself.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Thanks, Courtenay.courtenay wrote:G and H look to be the senders for the temperature gauge. The one nearest the radiator (without the wire) is the one that "pegs" the needle. The other is the one that controls the gauge itself.
Ummm... Both should be connected, right? The short wire to the closer point, and the longer wire to the farther. When both were connected, a mechanic found my temp needle went from dead centre to right of centre, about 1/8".
Happy Thanksgiving!
- courtenay
Fiat electrics??? My front sender (the one that pegs the needle) went faulty some time ago. I disconnected it - leaving the one that actually measures the temperature of the fluid as my only indication of fluid temperature. I have the new sensor, but haven't been able to get a socket on the old one to replace it - in the meantime, things seem to be operating just fine.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- joelittel
I'm also curious about the header labeled "D" in the picture above. Is it a stock header?
Mine, too.courtenay wrote:Fiat electrics??? My front sender (the one that pegs the needle) went faulty some time ago. I disconnected it - leaving the one that actually measures the temperature of the fluid as my only indication of fluid temperature. I have the new sensor, but haven't been able to get a socket on the old one to replace it - in the meantime, things seem to be operating just fine.
I have the short wire attached to the farther sensor, as purchased, and no issue...that I know of.
Thanks.
- Your car is a: 1975 124 Spider
Header is not stock ("D") but appears to be one of the commonly available styles.
FOR SALE: 1975 124 Spider http://fiatspider.com/f15/viewtopic.php?f=10&t=34477
Thanks, man. So that's what a header is! My car knowledge is woefully lacking, despite two manuals...707kevin wrote:Header is not stock ("D") but appears to be one of the commonly available styles.
The POs probably had a vision, I just wish they had left a note in the glove box.
Happy driving.
"A" and "B" need to be removed and the holes left behind plugged with the short bolt (can't remember the size/pitch off hand) The previous owner cut out part of the emissions system and simply crimped off the piping that leads into the head.
"G" and "H" are water temperature sensors. One is for the temp gauge, the other, if triggered by overheating, will peg the gauge into the red zone. ( I think that's how mine tested..)
What year is this? I don't see the relays on the driver side fender, or any of the vacuum electrovalve stuff. Probably better than it's gone unless you are going for factory original correctness.
Thanks, Kevin.707kevin wrote:"A" and "B" need to be removed and the holes left behind plugged with the short bolt (can't remember the size/pitch off hand) The previous owner cut out part of the emissions system and simply crimped off the piping that leads into the head.
I've plugged the holes with M18 drain plugs and Dope. No relays yet, but it sounds like a winter project. They're piling up for December. Electrovalve? I have no idea.
