Timing Belt Failure
ScoopMan
Your car is a: 1971 Sport Spider and 1979 Spider 2000
Timing Belt Failure
Post by ScoopMan »
Will a timing belt failure always cause internal engine damage? Or can one get lucky? My sense is that if it happens while driving, the crank will still be turning if the car is in motion and the trans is in gear. It would seem to me that SOME valves would HAVE to be stuck open, and would get hit by a piston. Maybe one might get lucky with a low compression 1995 cc with the big flycuts, but I imagine less so on the earlier engines.
Just wondering, as I am looking at buying a car that the seller claims had a timing belt failure, but was fixed without a teardown, and has been running fine for several years since...
divace73
Re: Timing Belt Failure
Post by divace73 »
most of the fiat engine are interference, however I believe the later 2L low compression aren't, can other chime in to confirm????
If the car the been running fine for several years after the repair, then I imagine then the proof is in the pudding...(if that saying is common??) it's fine...
Cheers David
see my >>You tube channel<<
the later 1800s would freewheel since they had deeper flycuts in the pistons
bobplyler
Post by bobplyler »
Also, in the 2L the crankshaft can hit the aux shaft.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
ScoopMan
Post by ScoopMan »
Well, it is a 1608, and the owner says it died while the car was stopped.
Ramzi
Post by Ramzi »
A 1608 is definitely an interference motor - so please be careful. I once had a 24 valve Alfa which lost a belt when it stopped... Not pretty - trust me.
Also, I recall seeing one 1995cc motor which actually had valve to valve interference when a timing belt failed. So even a non-interference motor can interfere.
ScoopMan
Post by ScoopMan »
Even with the car stopped and the engine turning at idle speed, there is still considerable rotational momentum from the crank and flywheel. I cannot see how a crank turning at 1000 rpm or so can come to an immediate stop. If it turns even one revolution, I would think there is no way for a piston to avoid hitting a valve that is stuck open.
dom
Post by dom »
Ask them if you can do a compression test, it's easy to do. If they say no then stay away.
ScoopMan
Post by ScoopMan »
Yes, I have already told them that I wanted to to a compression test, as a dead minimum.
