I purchased a 72 BC coupe with a disassembled engine - unclear if the transmission matches, it has the floating pin pistons which appear hard to find, and many other questions before my rebuild. I currently have a line on a running 1756. I have also gathered that the 1756 might be too tall for the hood but I'm not certain.
Can any one share some light on the feasibility and obstacles of doing this swap? Thanks -
1756 in a 72 BC Sport Coupe will it fit?
Re: 1756 in a 72 BC Sport Coupe will it fit?
I suppose the first question is can you plug a 78 spider 1756 in a 72 spider? I realize the hoodline on the coupe is a guess on everyone's part.
- Your car is a: 1970 128
In the US the 1608s came with the 215mm clutch, so the bellhousing/clutch/flywheel would be the same between the 1608 and 1756.
But it's easy to measure to be sure.
Yes, it will fit in a BC, people have put the taller 2 liter in a BC too, plus the later CC Coupe came with the 1756cc engine from the factory.
Can you send us pics of the car? I love BC's!!!
Hey guys - Thanks for the replies. I missed out on the donor car while figuring this out but i may just rebuild the engine this winter anyway.
It needs a ton of work but I love the lines. Im traveling for work now but will post photos when i get going on it.
