Hi there folks,
Is there anyone out there who has done a twin carb conversion on their 1800? I've got twin 40mm EMPIs going onto a RHD Spider with the Allison intake and would LOVE to see some detailed pics on how you set up your linkage to finish the accelerator cable to the carbs?
Also, did you run the cable to the end or middle between the carbs, what's best?
Regards,
David
Twin carb linkages for RHD Spider
- Your car is a: 1972 124 Spider
- Your car is a: 1977 124 Spider
Re: Twin carb linkages for RHD Spider
Hi David,
I have a 1756cc spider with dual 40 IDF's on a RHD car. I bought only a few months ago. It has the cable running to rear of the engine, with some form of linkages connecting the two carbies. I have the turtleback air cleaner off at the moment for a timing belt change, so should be able to take some photos for you. I am not sure about posting the photos here, but, if I get your personal email address from you, via a personal message, then sending the photos will not be a problem. My setup seems to work well, but I think that I need to have a stronger return spring between the two carbies.
Please let me know if you want some photos, as I see that it was a while since you posted the question.
Cheers,
Cheers,
John in Oz
First Fiat: 1970 124 sedan 1970 - 1976
Then horse float towing vehicles up to present.
Current Fiat: 1977 124 Spider 1756cc with twin Weber 40 IDF's
1970 124BC coupe; 1756cc with twin Weber 40 IDF's, used for sprinting
Ooops, my mistake, you only posted the question yesterday...
John in Oz
- Your car is a: 1970 128
Re email address for pics davecliff57@gmail.com will do it nicely thanks!
Hi Dave,
I have it all back together now, but still should be able to get some pics for you. Give us a few days, as we are on grandparent duty here at the moment.
Cheers,
Cheers,
John in Oz
