Strangling between 2000-3000 tpm...
tomlebatisseur
Your car is a: Fiat 124 spider 2000 from 1980.
Post by tomlebatisseur »
It remain a problem on my Spider 1980 injection.
When cold, i ve the problem very present.
When very hot , the problem reappear....slightly...
When "lukewram"....not very noticable problem....
I ve already clean the Air flow controller again and again....with a light sand paper.....it s not perfect , but it si free.
But what do you think of the Vacuum Advance Capsule? is it easy to change it? it s just under the ignition head....
How can i test it?
Thks
bradartigue
Re: Strangling between 2000-3000 tpm...
Post by bradartigue »
You need to test the temperature sensor, located in the "T" between the coolant hoses.
tomlebatisseur
do you mean the by pass T thermostat? or the bleed plug a union between the motor and the coolant hose pipe?
bradartigue
tomlebatisseur wrote:do you mean the by pass T thermostat? or the bleed plug a union between the motor and the coolant hose pipe?
I mean the sensor in the T where water exits the head.
