Auxiliary Timing (SOLVED)
131
Re: Auxiliary Timing (SOLVED)
Post by 131 »
ScoopMan wrote:bump for some help.... I am guessing that the mark I want is the notch to the left. There is also a hole that can be seen off the shaft that appears to line up with it. Is anyone familiar with this pulley design?
I am kicking myself now for not having the sense to mark these pulleys with white out before I pulled the belt. Doh! :oops:
131 wrote:If you look at the above photo, in the centre of the pulley @ about 1 o'clock is the hole for the locating dowel. If you reference it in line from the centre to the outer edge of the pulley, it's about 2 teeth anti clockwise to the timing mark. Have a look where the marks are on your pulley in reference to the locating dowel.
Mick.
ScoopMan
Your car is a: 1971 Sport Spider and 1979 Spider 2000
Post by ScoopMan »
Thanks everyone. Hugely helpful. Now all I need is some more free time to finish the job while the weather is still nice :)
