For the first time in two+ years of ownership, and operation as my daily driver, I have a puzzling electric problem.
My lights and wipers won't work if the ignition is on. If I turn the switch off, they work.
What is the cause of this?
lights and wipers only work wioth ignition off
- spidernut
Re: lights and wipers only work wioth ignition off
If you didn't move any wires around, you most likely have a bad ignition switch.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
- Patron 2024
Have you replaced the ignition switch with an aftermarket switch??
No. Haven't touched anything electrical in a long time.spider2081 wrote:Have you replaced the ignition switch with an aftermarket switch??
- Patron 2024
This is a strange problem. What year is your car. Have you inspected the ignition switch connections?? First thought would be ignition switch but if the mechanical part of the switch slipped to put off the position alignment I would expect more than 2 issues.
