Throw-Out Bearing noise?
70spider
Post by 70spider »
When the car is idling in neutral there is a rattling noise coming from the bell housing area. Then when I push the clutch in it goes away. I am sure it is rattling when I am driving but due the engine noise I can not tell. My amatur guess is it is the throw-out bearing, but my clutch seems to be working perfectly. Any thoughts?
2002 Mazda Protege5
2013 Buddy 170i
131
Re: Throw-Out Bearing noise?
Post by 131 »
Gearbox input shaft bearing. If the clutch is adjusted correctly, the throwout bearing shouldn't be contacting the diaphragm fingers until you put your foot on the pedal, so shouldn't make a noise.
Mick.
Exit98
Post by Exit98 »
My experience is that they all rattle a little when the clutch is depressed. I changed mine cuz of the noise and a squeal, but it turned out to be a bad pilot bearing.
70spider
Post by 70spider »
Thanks for the input. I'll have to wait a couple of months before I can pull the tranny so I hope it holds out :) .
2002 Mazda Protege5
2013 Buddy 170i
