Subwoofers n Stereos
scampbel98
Your car is a: 1980 Fiat 124 carb
Contact:
Post by scampbel98 »
Thought I'd share a pic of my amp and subwoofer install
Sony amp + 2x 8" subs.. custom box out of 1/2" MDF
The floors torn up so I could remove bumpers etc for paint.
Yes... it does need a little anti-rattle mat :)
Wife said "no subwoofers if i lose any trunk space - we were both OK with this trade off.
Image[/URL]
Ptoneill
Re: Subwoofers n Stereos
Post by Ptoneill »
Where did you relocate the battery? Shouldn't the sub woofers face the people part of the car?......not bring a wise guy I honestly don't know?
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
scampbel98
Contact:
The battery is still there. Unmoved. :D
It's a flat board in front with speaker boxes to the back for the subs. Each cavity was like .9 cu.ft. which was just enough per the subwoofer specs. (you have to have specific air volume for sealed box subs to work right.
And with subs, it doesn't matter where they are or where they're pointed. In this case, the trunk cavity actually works like a 2nd speaker box. I get pretty good base response outta this setup.
Ptoneill
Post by Ptoneill »
Thanks for the info!
Stay Safe,
Pat
79spider
ptoneill@msn.com
TX82FIAT
Post by TX82FIAT »
The anti rattle mat is going to be required. The metal on the trunk is pretty thin and the reverberation might send waves through the metal. There are two seams above the trunk lid that go vertically between the trunk and the rear window. These areas are likely to have some paint cracking with the increased body flex and vibration. On the 83-85 spiders they redesigned the top boot with metal hooks and a piece of metal that extends down to the trunk lid to hide this common cracking area. I only mention this because you said you removed bumpers for paint. It is highly likely the new paint will show cracking after it fully cures in that area in a short period of time.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
DieselSpider
Post by DieselSpider »
scampbel98 wrote:The battery is still there. Unmoved. :D
Will the sonics help keep the battery desulfated?
