Aluminum radiators!-direct replacement
- Your car is a: 1975 124 Spider
Re: Aluminum radiators!-direct replacement
Do Want!
FOR SALE: 1975 124 Spider http://fiatspider.com/f15/viewtopic.php?f=10&t=34477
- Ptoneill
Mark,
Looked on line and did not see any on your shop site. Do you have these in stock?
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
our first batch has sold out. We have a container that arrived last week and we're waiting for it to clear Customs. I expect to have the radiators by mid-week
The initial batch was priced at $189 but those are gone. We got slapped with Customs fees that have forced a price increase to $229
- Ptoneill
Mark,
Bummer on the price....but I ordered mine today anyway!! Just confirming these radiators take a standard radiator cap?....and before I buy one off the shelf are you planning on making a cool billet cap....?
Anyone need a re-cored OEM 124 2000 radiator that's never been used?..was set up for an auto transmission but that segment was plugged upon rebuild.
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- Your car is a: 1977 Spider
Mark, I'm guessing you are the guy selling them on eBay for $229. If so, I might be ordering one soon. The flange that holds my rad cap on cracked off and I've tried soldering it on twice to no avail. Is there another way to order besides eBay, I checked your site and didn't see them on there.
they will be on my site in a day or two. The Fiat cap fits them. I'm not planning a billet cap just yet
if anyone uses one with a 1608 car could you post info on the install process?
For a 1974 or earlier car you would have to lower the lower radiator saddle, otherwise the radiator will sit too high
I recall you mentioning that I just want to see how someone does that. Is it just the rubber saddle or the welded on bracket that need to change (or both?)
the welded bracket will have to be lowered
I ordered one of the first and it installed perfectly in my '81... had an aftermarket fan and bracket attached as well.
Car is still on the lift finishing suspension and exhaust and pinion etc etc etc... have not run yet but she should be tuned and ready to roll in 2 weeks.
- DaveT
- Your car is a: 1978 Spider
Mine is due in tomorrow!
Dave T
Warwick, RI
'78 Black Spider
Warwick, RI
'78 Black Spider
Will this aluminum radiator fiat with the 79 2000 AUTOMATIC TRANSMISSION????
- Ptoneill
There are two different radiator shrouds and of course 79 was a crossover year. If you are using the stock fan and shroud make sure you measure between the two bolts on the right side of the shroud, and then call Mark's shop to ensure the shroud you have will fit, I think the measurement you want is around 11.5 inches.
That being said I have an auto transmission car, the radiator fits great....however you will have to install a separate transmission cooler.
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
