Hose shut off question
CharlieB
Your car is a: 1976 Fiat Spider
Post by CharlieB »
The previous owner of my 76 Spider installed a shut off valve on the hose running to the heater core. I wanted to install a flush T to help with burping the cooling system. Is it safe to replace this valve with the T?
Here is a picture of the shut off valve. https://picasaweb.google.com/lh/photo/B ... directlink
Thanks guys
1976 Fiat 124 Spider
redcars
Re: Hose shut off question
Post by redcars »
Do you have a valve inside the car for the heater? If not the when you replace this with a fill T it will be on full heat all the time. Why did the PO put the shut off valve theŕe, a leak in the heater core, or to replace the original valve f that no longer is in the car? If eathere of these zthan you must take care of these fitst.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
CharlieB
Post by CharlieB »
Thanks for the reply redcars. I just got this car a few days ago and its my first Fiat so I'm still trying to learn what I have. To answer your question, no, there is no valve inside the car. Just the valve from the photo. I think I will abandon the flush T idea for now. I now have more issues to deal with on this car (major engine problems). Thanks again
