Thanks, Brad. I did replace the temperature sensor. The old one looked like it might have been original, and as it's such an important component, I swapped it out for peace of mind even if it didn't solve the idle problems (which it didn't). As I mentioned before, the really odd thing is that unplugging the temp sensor prevents the extreme RPM dive that I experience a few seconds after starting.bradartigue wrote:I'm not reading if you replaced the temp sensor or not, but if you suspect it at all, replace it. It can cause a lot of problems if it "thinks" you car is colder than it is.
I'll post a summary at some point because this is a lengthy thread, and I hope it can be of assistance to folks in the future. Covers several typical FI problems that new Spider owners encounter.
