timing belt tool
rlmiller
Your car is a: 1977 spider
timing belt tool
Post by rlmiller »
Has anyone tried to make one of the factory tools that hold the camshafts from moving during a timing belt change. One of those would have made my life much simpler last year.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming-Wow! What a Ride! Hunter S. Thompson
azruss
Re: timing belt tool
Post by azruss »
I actually wouldn't want to use one. As i thread the belt on it is a benefit to have the cams "float" as that allows me to pick up a tooth and then tension the belt as i to through the sequence. And as most things automotive it would have be nice to have a couple of extra limbs for the job. Especially if they were long, skinny, and had several joints :mrgreen:
rlmiller
Post by rlmiller »
Yea, a highly trained squid would be advantageous :D
fiatfactory
Your car is a: 1970 128
Post by fiatfactory »
djape1977
Post by djape1977 »
rlmiller wrote:Yea, a highly trained squid would be advantageous :D
one of these days somebody in genetic engeneering industry will come up with mechanic with octopuss DNA :mrgreen:
you don't need any special tools to replace timing belt on a fiat.
bradartigue
Post by bradartigue »
fiatfactory wrote:At my dad's dealership we had the alignment tool, but no one ever used it as it's a PITA. Timing belt is only semi difficult the first time around, once you've done it a few times it's second nature.
SteveC
Did they make one after the 1438 engines? Curious though I agree - too easy to need to use it.
