Where can I get a replacement for my 1977 Spider alternator? None of my local parts shops have one or can get one. The mail-order Fiat-parts sources need mine to rebuild. Where can I get one ready to go? Or, is there some simple alternative from another car that is a drop in or close to it? I have looked at GM units, but it looks like they will need a fabricated mount.
I won't use a one-wire unit.
Need replacement alternator
Re: Need replacement alternator
Where do you hang your hat? Anyone nearby?
- Your car is a: 1980 spider 2000
just curious: why won't you use a one-wire alt? this has done magic for my car: http://www.allisonsautomotive.com/produ ... electricalsdebaker wrote:Where can I get a replacement for my 1977 Spider alternator? None of my local parts shops have one or can get one. The mail-order Fiat-parts sources need mine to rebuild. Where can I get one ready to go? Or, is there some simple alternative from another car that is a drop in or close to it? I have looked at GM units, but it looks like they will need a fabricated mount.
- mik
- seabeelt
- Patron 2019
I might have one. How many amps?
narfire wrote:Where do you hang your hat? Anyone nearby?
I'm in the Portland, OR USA area. I think I have exhausted all the local possibilities for a new or rebuilt unit. There is a possibility that I can get this one rebuilt locally. But, If I can find one ready to go, it might be better.
When? Do you have a part number? I checked their website and there was no alt listed for my car.lanciahf wrote:I got mine from rockauto.com, its a Bosch 65 amp.
I have experience with one-wire units. The machine-sensing technology is relatively crude compared to battery-sensing technology. One-wire does not respond as efficiently to changing load conditions as battery-sensing systems. MS works for rodders I suspect because of the limited use of their cars. If one-wire was really good, it would be the only thing automakers use, because it is cheaper to do.autotransgression wrote:just curious: why won't you use a one-wire alt? this has done magic for my car: http://www.allisonsautomotive.com/produ ... electricalsdebaker wrote:Where can I get a replacement for my 1977 Spider alternator? None of my local parts shops have one or can get one. The mail-order Fiat-parts sources need mine to rebuild. Where can I get one ready to go? Or, is there some simple alternative from another car that is a drop in or close to it? I have looked at GM units, but it looks like they will need a fabricated mount.
interesting. thank you. but i do wonder how big a deal that would be on a car with such minimal demands. i could see the importance on maybe a super duty with huge lighting systems and a trailer with lots of appliances, but a little old spider?sdebaker wrote:I have experience with one-wire units. The machine-sensing technology is relatively crude compared to battery-sensing technology. One-wire does not respond as efficiently to changing load conditions as battery-sensing systems. MS works for rodders I suspect because of the limited use of their cars. If one-wire was really good, it would be the only thing automakers use, because it is cheaper to do.autotransgression wrote:just curious: why won't you use a one-wire alt? this has done magic for my car: http://www.allisonsautomotive.com/produ ... electricalsdebaker wrote:Where can I get a replacement for my 1977 Spider alternator? None of my local parts shops have one or can get one. The mail-order Fiat-parts sources need mine to rebuild. Where can I get one ready to go? Or, is there some simple alternative from another car that is a drop in or close to it? I have looked at GM units, but it looks like they will need a fabricated mount.
- mik
I searched under 81 spider, looks like they have one left. I converted a 70 spider with an external voltage regulator to an alternator with a internal voltage regulator using a later model alternator.
ACDELCO 3341075 {#19134068} Professional Remanufactured; Does Not Include Pulley; 65 Amp; Does Not Include Pulley
Unit Mfr: Bosch; Amps: 65; External Fan; Internal Regulator; Clock: 10:30; w/ AC
http://www.rockauto.com/catalog/moreinf ... 485&jpid=0
sdebaker wrote:When? Do you have a part number? I checked their website and there was no alt listed for my car.lanciahf wrote:I got mine from rockauto.com, its a Bosch 65 amp.
