I got a set of aftermarket fender liners from Autoricambi.......very fast shipping by the way!! I am now struggling with fitting them in the wheel wells. I am hoping that someone has pictures showing how the edges line up against the fender and the fastener points to attach the liner to the body.
I have tried tucking the edges of the liner up against the rolled fender edging but I am not even close to lining up the 6 pre- drilled holes where the front and rear segments attach to each other. Any help would be appreciated.
Fender Liners install question
- Ptoneill
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
Re: Fender Liners install question
Pat,
These have been on quite a long time so i garantee you they are not from auto Ricambi, but you said any help is appreciated. Hopefully it helps.
View is driver's side view. Four phillpis head screws hold each liner. There is no coverage from liner at the fastener nearest the tie rod.
