Hi,. My 1976 1800 spider hesitates to take the gas when I put my foot down to sudden, otherwise there is fine response.
Am I on the right track assuming that it could be the accelerator pump ? gas filter, air filter and fuel pump is new.
Do I have to buy a new pump and how difficult is it to replace, I am still very, very green in all this but wish to learn without trashing the car.
Greetings from sunny Denmark ( finally )
accelerator pump
- Your car is a: Spider 124 1800 coupe 1976
Re: accelerator pump
the pump diaphragm may be bad, but the pump discharge nozzle could be plugged or the o-ring that seals the pump nozzle could be leaking. Make sure the ignition timing is correct and that the mechanical advance works
Can I identify the model of my weber without taking it out ?
- bradartigue
You don't really replace the "pump" - just the diaphragm inside the pump. Very easy to do.Antileon wrote:Hi,. My 1976 1800 spider hesitates to take the gas when I put my foot down to sudden, otherwise there is fine response.
1970 124 Spider
http://www.artigue.com/fiat
