Hello all, I just replaced the speedometer cable in my 79 spider last night, and after I got it done, I realized that I had not put any kind of lubrication in it. Is this generally required for new cables or do they come good to go? The link below is the cable that I bought.
Thanks!
http://www.vickauto.com/newstore/index. ... ts_id=1874
SPEEDO CABLE LUBE QUESTION
Re: SPEEDO CABLE LUBE QUESTION
They are usually good to go however if you feel it was old stock you can get the lube at most parts stores:
http://www.oreillyauto.com/site/c/detai ... &ppt=C0338
Thanks for the info. It looks to be new and not NOS. I may pick some of that up just to be safe anywaysDieselSpider wrote:They are usually good to go however if you feel it was old stock you can get the lube at most parts stores:
