Will this Marelli Electronic Ignition work on my spider
kmoses
Post by kmoses »
I have been given a NOS Magneti Marelli electronic ignition that does not have vacuum advance. The numbers on the base of the distributor are SM801AX -- 802R2 802P2 9J. My engine is 2.0L w/ 1800 head, intake and 32 ADFA carb. My question is will this work on my engine and if so, is the timing set the same as stock?
131
Re: Will this Marelli Electronic Ignition work on my spider
Post by 131 »
I've got the same distributor on my engine, except it ends in 3K, not 9J. I don't recall seeing a VA on a Fiat dizzie, it must be a Yank thing. I run mine at 10deg static, I did try 15deg when I fitted the IDFs, head and cams, but it tended to ping a bit, so I backed it off.
Mick.
kmoses
Post by kmoses »
I found the factory invoice tucked in the box (new in 1990) and orderd from Bayless, Inc. in GA. now Midwest-Bayless in OH..
Called and spoke with Matt and he said set the base timing at 12-15 deg. BTDC and at 3500 RPM it should be 30 deg. max. and that these are NLA. Thanks for letting me know what your setup is.
