timing belt movement
chrisfiat
Your car is a: 1976 124
Post by chrisfiat »
just replaced the leaking exhaust cam box gasket and reinstalled my t belt. This is the first time i have ever started and run the engine w/o the cover on the belt, and much to my amazement it walks all over the the cam and crank gears. It is rithumatic with the crank sprocket, and does it at any rpm., I never comes up against the cam sprocket shields, but it is an extreme movement and makes me a little concerned. I have never seen it on any of my vw's or toyota's.
Is this totally unusual or am i just worrying too much
seabeelt
Patron 2019
Patron 2019
Re: timing belt movement
Post by seabeelt »
Check the idler bearing...... They do wander some.....
chrisfiat
Post by chrisfiat »
the idler is new
pluktv
Your car is a: 1979 spider
Post by pluktv »
I had a problem with my plastic auxiliary sprocket doing a similar thing. I checked it off the car and under very close examination it had worn quite 'untrue'. I think (someone will no doubt correct me) you can replace them with steel ones now.
My two cents ain't worth what it used to be
chrisfiat
Post by chrisfiat »
both my sprockets are plastic, might be time for a new pair of steel ones
carl
Post by carl »
The plastic sprockets should be replaced as they have a bad habit of coming apart with the center hub separating from the rest of the sprocket. If one of your plastic sprockets in the process of cracking making the sprocket rock on the center hub I suppose it could cause your belt to wander on the sprockets.
carl
focodave
Post by focodave »
I would definitely replace the plastic gears with that new substitute for plastic, called "metal".
1970 MGB GT (my other hobby)
