Custom designed clutch arm for v6spider..
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Re: Custom designed clutch arm for v6spider..
Post by v6spider »
Here's the finished clutch arm.. I installed it yesterday and it works beautifully!
http://www.v6spider.com
v6spider
Post by v6spider »
Back in the saddle again! 8)
Cheers!
Rob
SoFlaFiat
Post by SoFlaFiat »
Fantastic!!
Nice work Rob!
Now, I wish there were some roads around here like you guys talk about! I can go dead straight and flat in 180 degrees of the compass for at least 2 hours before I hit a curve needing any attention! Jealous I am!!!
v6spider
Post by v6spider »
SoFlaFiat wrote:Fantastic!!
Nice work Rob!
Washington is quite mountainous on the coastal side. The eastern side has more flatter areas although the Columbia river gorge is similar to the grand canyon.
Cheers!
Rob
cormac
Your car is a: Fiat 124 spider 1976
Post by cormac »
Alan, just a small sampling, all from a portion of about a 70 mile jaunt...oh and if you get tired of the drive then just pull over at one of the falls and soak the feet
divace73
Post by divace73 »
v6spider wrote:Back in the saddle again! 8)
Cheers!
Rob
good stuff, I really like how you have kept everything under the bonnet (hood), real neat
We need some audio....
Cheers David
see my >>You tube channel<<
v6spider
Post by v6spider »
cormac wrote:Alan, just a small sampling, all from a portion of about a 70 mile jaunt...oh and if you get tired of the drive then just pull over at one of the falls and soak the feet
Is this the Oregon Coast? Looks like Chuckanut Drive!
v6spider
Post by v6spider »
divace73 wrote: good stuff, I really like how you have kept everything under the bonnet (hood), real neat
Here's a video... audio is so so..
https://youtu.be/7mD-vUBLk8w
Cheers!
Rob
cormac
Post by cormac »
Historic Columbia River Highway from Troutdale to The Dalles
it was always fun when you recognized one of these roads in a car commercial on TV...Portland had a few major ad agencies and wet roads seem to be preferred for commercials
DieselSpider
Post by DieselSpider »
Nice work Rob!
Check out the Motorcycle Roads web site as there are some roads of note here in Florida hidden about:
http://www.motorcycleroads.com/category.php?id=85
DieselSpider
Would using an external slave cylinder be an option?
http://www.jegs.com/i/McLeod/673/139006 ... Id=1503743
Personally I rather despise the ridiculous cost that the internal slave cylinders added to the job of replacing the slave cylinder when they went from external to internal especially on a front wheel drive vehicle. Usually when the internal slave cylinder fails it leaks out on the clutch saturating it with oil turning what was a $30 job of rebuilding the easily accessible slave cylinder into a two day job of dropping the front suspension, removing the trans-axle, cleaning up the mess, replacing the slave cylinder and the clutch along with having to put everything back together again.
I know some folks into off roading who are a bit tired of the internal slaves built into the throwout bearings and are replacing them with external units for ease of servicing on site when away from civilization.
v6spider
Post by v6spider »
DieselSpider wrote:Would using an external slave cylinder be an option?
Already fixed it.. The cable system working great with that custom clutch arm I made.. Cost me $20.00. :) rock on!
Cheers!
Rob
DieselSpider
v6spider wrote: Already fixed it.. The cable system working great with that custom clutch arm I made.. Cost me $20.00. :) rock on!
Cheers!
Rob
Simple is many times best. Spare cable takes up little space and is much easier to install than a slave cylinder if one fails.
JinxaHappy
Post by JinxaHappy »
Alot of high schools or automotive college classes have CNC mills and even laser and hydro tables.
