Valve Covers
- aj81spider
Valve Covers
How tightly should the valve covers be tightened down? I had mine torqued pretty tight. A shop did some work on the car, and decided to check my shim clearances. When I drove it home there was oil all over the top of the engine and I noticed that the hold downs were only finger tight.
A.J.
2006 Corvette
2006 Corvette
- aj81spider
Re: Valve Covers
Thanks Mark,
That's not very tight - what would cause leakage? I seem to have a lot!
A.J.
2006 Corvette
2006 Corvette
Re: Valve Covers
If you over tightened the covers, they may be warped. Check them on a granite block like what a machine shop has. You may have squeezed the cork gasket out at the tight spots. I use a gasket cement to glue the gasket down on one side only. this keeps it from squeezing out of place when tightened.
- aj81spider
Re: Valve Covers
Thanks - I'll pull them off an check flatness. Mine have a rubber gasket, though, not cork.
A.J.
2006 Corvette
2006 Corvette
Re: Valve Covers
A good cast and machined table saw top is flat enough to check them, I use my Delta Unisaw for this sort of thing.
