77 Fiat Spider
32 ADFA carb, California emissions (must remain intact due to smog checks), Catalyst car
I am replacing vacuum lines due to age and emissions problems and ran into a HUGE issue. I have consulted with the Fiat shop manual, Haynes Manual, Chilton's manual, Brad Artiques ADFA manual, the Weber ADFA manual, this forum and Mirafiori.com. They all seem to be incomplete in this area and contradict one another.
Let's start with the shop manual picture:
Port 1: The Fiat manual states this is the crankcase blow by connection. Another graphic in the Fiat manual shows it goes to the small air port on the bottom of the air filter canister above the crankcase ventilation hose. However, the other manuals show it goes to the top of the charcoal canister. So which is it? Does it go to the air cleaner or the charcoal canister?
Port 4: This is the float bowl vapor outlet. Logically, it would connect to the charcoal canister but NONE of the manuals depict or describe where it connects at the other end. Top, side? Somewhere else entirely?
Port 8: The Fiat manual says this connects to the vapor canister. Top, side? The other manuals don't depict this port at all. Gheez.
Port 10: The Fiat manual lists it as the EGR vacuum source. The pictures depict it connecting directly to the thermal control valve then to the EGR valve. However, there's a front electrovalve located on the driver's side fender that has been described by others on the forums as the EGR electrovalve. The electrovalve, of course, is not mentioned in ANY of the manuals. The only one mentioned is the fast idle electrovalve which is connected per the Fiat manual. How are the vacuum lines to be run for the EGR electrovalve if that is what it really is?
If you know how these are supposed to be run properly (again, I cannot disconnect the emissions system), please let me know. The manuals are so incomplete and contradictory it is mind blowing. I'd default to the Fiat manual but it is incomplete as well.
HELP!
