cold start injector resistance?
burlybryan
Post by burlybryan »
I'm doing some cold start tinkering today and rechecked my cold start injector. It's a new injector (year old), but has never worked, so I'm unsure if the issue is signal, the injector or fuel. It gets power (lights a noid light) but doesn't squirt. The pins on the injector measure 7.2 ohms, but I don't know what is spec. Anyone know?
Once started, the car runs great, but has always taken 5-10 minutes of cranking in temps under 50f or so.
Thanks.
Bryan
burlybryan
'82 Spider 2000 FI
'12 500 Sport (Verde Oliva) - wife's daily driver - when it's not being fixed at the dealer...
spider2081
Patron 2024
Patron 2024
Re: cold start injector resistance?
Post by spider2081 »
I don't have a published spec. I did check 4 cold start valves resistance with an inexpensive digital meter. They all measured about 5 ohms. More important than the resistance I would apply 12 volts DC to the valves pins. They are a solenoid and make a very audible click. You could also connect a short hose to them, pour some fluid in the hose. Apply the 12 volts while blowing in the hose and the fluid should come out of the valve. I believe the cold Start valves are very reliable. The temp sensor in the intake manifold that controls the valve is much more troublesome.
GeorgeT
Post by GeorgeT »
You may have a bad thermal sensor. If the car is at warm the Cold Start injector does not fire.
burlybryan
Thanks guys. I like the idea to test it w/ voltage. The thermal sensor is newish as well. Replaced it early on in the quest.
burlybryan
'82 Spider 2000 FI
azruss
Post by azruss »
I would look at the cable as well. They can break an 1" or so from the injector.
