Bucking at 1700 - 2100 RPM
wubie317
Post by wubie317 »
Recently, the car has started bucking...surging, lurching, not smooth...at exactly 1700 RPM. It's like riding a bucking bronco until it gets to 2100, then all is fine. All gears.
Where should I start looking for a cause?
azruss
Re: Bucking at 1700 - 2100 RPM
Post by azruss »
I would start with fuel. clean carb, change filter. Also, pull your plugs and see who they look. how do plug wires look. tight on both ends.
124JOE
Post by 124JOE »
also pull the cap and inspect it and the rotor
vandor
Post by vandor »
Fuel pressure should be checked, not enough fuel often causes bucking on both carbed and FI cars.
if you post more information about the car you'll get more specific answers
76was124
Patron 2019
Patron 2019
Post by 76was124 »
Ditto what Mark said.....what year? Engine? FI or carb etc.
Also, does it happen in that rpm range in all gears?
Current 81 Spider 2000
Previous 76 Spider
toplessexpat
Post by toplessexpat »
Looks like a '77 - and this ain't its first rodeo (oh I'm laughing at my little joke there....)
http://fiatspider.com/f08/viewtopic.php ... 21#p226421
www.mirafiori.com
