Backfire
Re: Backfire
This backfire incident happened the day before I left town and y'all may find it hard to believe but I didn't even pop the hood to take a look. The winter is usually my driving season but its even been cold down here below sea level. So, I'm not as motiivated as I would normally be to get her running. Popped the hood this morning and found that the air flow snorkel (hose or whatever it's called) was detached at the end opposite the airflow meter/air box. Left it like I found it even though the car is garaged. If the weather is good tomorrow I'll reattach it and let y'all know what happens. Suprised and appreciative of the interest. Brad, if it's anything more complicated than slipping the hose back on you'll have to return to the area to fix it!
- bradartigue
Re: Backfire
I'll do it myself this time!ralphcap wrote:This backfire incident happened the day before I left town and y'all may find it hard to believe but I didn't even pop the hood to take a look. The winter is usually my driving season but its even been cold down here below sea level. So, I'm not as motiivated as I would normally be to get her running. Popped the hood this morning and found that the air flow snorkel (hose or whatever it's called) was detached at the end opposite the airflow meter/air box. Left it like I found it even though the car is garaged. If the weather is good tomorrow I'll reattach it and let y'all know what happens. Suprised and appreciative of the interest. Brad, if it's anything more complicated than slipping the hose back on you'll have to return to the area to fix it!
1970 124 Spider
http://www.artigue.com/fiat
Re: Backfire
Improved weather so I pushed my spider out of the garage and discovered that both ends of the air hose were detached as a result of the backfire. Did not notice any other problems so I reattached both ends. She started up right away and I took about a half hour spin and she ran well.
- bradartigue
Re: Backfire
Well then Ralph, did you tighten the thing on both sides this time? Because.......it doesn't fall off on both sides unless it is loose.ralphcap wrote:Improved weather so I pushed my spider out of the garage and discovered that both ends of the air hose were detached as a result of the backfire. Did not notice any other problems so I reattached both ends. She started up right away and I took about a half hour spin and she ran well.
Glad it is running. I would have hated to be right about a valve or wrong about your sparkplugs, magicwrench would have either had to add a 6th digit to his hand OR i'd have to eat crow about the valve being sticky.
1970 124 Spider
- Patron 2019
Re: Backfire
Dare I ask if the root cause of the back-fire should be a concern?
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
- bradartigue
Re: Backfire
I can guess at the root cause - the hose was loose on both sides. It moves to and fro (the engine isn't connected to the air box except by the hose). It got cold, shrunk, it fell off. When hot it expanded (in all directions) and tightened.76was124 wrote:Dare I ask if the root cause of the back-fire should be a concern?
Usually when it blows off the air forces it the hose off the AFM side after it blows the door backwards or the safety door on the vane open. The big boom is not from the air blowing the hose off, it is the engine gulping a big blast of unmetered air, causes a backfire...er, frontfire?
1970 124 Spider
- Patron 2019
Re: Backfire
Sorry, my question probably wasn't very clear. I was wondering what likely caused the initial back-fire, and should the cause of the back-fire be of concern? Or did you answer that by saying a loose boot (basically causing a high lean condition) is a possible cause of a backfire, which blew the boot all the rest of the way off?
Previous 76 Spider
Previous 76 Spider
Re: Backfire
I had a hose clamp on the Air Flow Meter side of the Air Intake Hose but did not have a hose clamp on the opposite side (intake manifold side?). Sounds like I should have a clamp on both sides and that they should be as tight as I can get them.
Re: Backfire
Yes hose clamp both ends, firm but not overly tight.
- bradartigue
Re: Backfire
No idea - sounds like the thing just fell off. Then in a few milliseconds it takes in a big gulp of unmetered air and the engine is already dying, so it blasts is all back out the wrong way, or through a half open valve.76was124 wrote:Sorry, my question probably wasn't very clear. I was wondering what likely caused the initial back-fire, and should the cause of the back-fire be of concern? Or did you answer that by saying a loose boot (basically causing a high lean condition) is a possible cause of a backfire, which blew the boot all the rest of the way off?
1970 124 Spider
Re: Backfire
Well, thanks everyone. Installed clamps on both ends of the Air Intake Hose. Glad it was something simple. Now all I need is much improved weather! Over and Out!
