I installed a set of these headlights in a project I'm working on and did a video of they function. The video quality is poor due to the brightness of the LEDs, but you get the idea of the lighting intensity
http://youtu.be/UMGkdwgVYw0
more front light options
- Ptoneill
Re: more front light options
I love the look of the headlights...Sadly I have not hooked up all my electrical to see how nice the are. These lights are of high quality and were simple to install.
I did screw up though when I installed the aftermarket headlight relay kit from IAP. I did not have the drivers side headlight positioned properly and when I tightened the retaining ring I put stress crack in the lens.....bummer.
Mark do you sell the bulbs individually or do I have to buy a set?.........although a spare is probably not a bad thing.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
they come to us in sets but I may have a single unit for you.
- Ptoneill
Thanks Mark! I will call on Monday as I also want a short stainless heater pipe.
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- Ptoneill
Mark came thru again...new headlight on its way hopefully this time I will ensure the lugs are lined up properly before putting on the retaining ring! These really are vey bright lights, I am using them in conjuntion with IAP's headlight relay kit.
Here is light on, I could not get a direct picture due to the glare.
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
definitely take some time to make sure the lamp is seated in the bucket properly! With relays, these lights make night driving a delight
- Ptoneill
I got the new headlight and heater pipe today, thanks Mark!!
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
