Can we talk 124 Coupe?
georgeramos
Your car is a: 1971 124 Spider 1608
Re: Can we talk 124 Coupe?
Post by georgeramos »
Mark, do you sell a solenoid of that type and can you explain it's usage/function a bit more? It sounds like an upgrade to the good old "brown wire fix"
I'm interested in doing this to all 3 of my cars and i think a step by step post (with photos) would be very helpful for the forum. id be happy to do that once i understand what's needed.
thanks
I get them as I need them, but it's not a problem for me to obtain them.
They're pretty simple to install; take all of the wires from the ignition switch that get fed power with the switch on and attach them to one large post on the solenoid. The other large post gets battery power, the easiest spot is from the starter battery post. Connect a wire from the ignition switch ON terminal to the small post on the solenoid. This is the same theory as the multiple relays, just a lot less wiring. The solenoids are designed to carry high amp loads. These look similar to the old Ford starter solenoids but they are continuous use, not intermittent like the Ford units.
http://www.bing.com/images/search?q=con ... tedIndex=0
RoyBatty
Post by RoyBatty »
I picked up some new side view mirrors for the coupe.
Found them on ebay and for the price, I expected to be underwhelmed.
Turns out, they are very nice. I think I'll get another pair for the Spider.
Does anyone know the origins of this mirror design?
RoyBatty
Post by RoyBatty »
Finally took time to install those mirrors.
I think I'll leave them on.
I also just received a glove box from Italy. Got it installed and now I just need to see the struts that support it on either side so I can fabricate some.
RoyBatty
Post by RoyBatty »
Just got the rear seat back from the upholstery shop.
ital
Your car is a: 124 sport coupe 1972
Post by ital »
Nice work! Tight, not full of ripples. Are you getting the fronts done?
the new Fiat 124 coupe only website @
http://www.fiat124sportcoupe.com
RoyBatty
Post by RoyBatty »
Hi ital,
Yes, I will be having the fronts done also.
But a new headliner is next on the list for the interior.
sptcoupe
Post by sptcoupe »
Great progress! Keep us posted.
ital
Post by ital »
yes good progress
you were not planning on contacting me for one of these were you?
http://www.ebay.com/itm/Fiat-124-coupe- ... RK:MESE:IT
RoyBatty
Post by RoyBatty »
Hi ital,
Yes I want to pick that up from you.
Problem is funds right now.
I need to do another couple side jobs to get that from you. Is it the only one you have?
Was out doing some work today and snapped this shot.
I have no idea why it turned out like this.
ital
Post by ital »
Ok will put you on the waiting list (another fellow is ahead of you)
No that one is gone. Another “couper” had to have it now, so closed the listing.
RoyBatty
Post by RoyBatty »
ital,
Is the headliner you offer NOS?
Or are you having them made from a pattern?
I am unclear as to whether or not you have another for me to purchase in the future.
I am guessing that your mention of putting me on a list implies you have access to more.
ital
Post by ital »
ital,
No non available at the moment . I think I have found more NOS material. If that pans out I can offer 3 more headliners in the near future.
RoyBatty
Post by RoyBatty »
Please keep me posted.
Thanks.
Did a mileage check and got 24 MPG on the highway cruising at an average of 70 MPH.
georgeramos
Looking amazing! i have done nothing to mine yet but still dream about the day i can afford to begin...
