No fire
Estepp14
No fire
Post by Estepp14 »
I have 1972fait 124 spider went to start it and nothing no fire put new coil on still no fire I need some help with this please
bobplyler
Re: No fire
Post by bobplyler »
Have you checked the points, rotor and rotor cap?
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
bradartigue
Re: No fire
Post by bradartigue »
Posts
are easier to read if you
use some kind
of punctuation
and
s
e
n
t
e
n
c
e
structure
(The above is at least as annoying as trying to read what you wrote) :)
Did it before you put on a new distributor? If so then check that you have the new distributor timed to the #4 firing position (not #1 like every other car, #4).
Re: No fire
Consequences of everything moving to those damned cell phones ("mobile devices").
spiderdan
Your car is a: 1968 124 Sport Spider
Re: No fire
Post by spiderdan »
RRoller123 wrote:damned cell phones
And they call them "Smart phones" :lol:
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
2016 Jeep Wrangler Sahara Unlimited (cottage toy)
http://s1342.photobucket.com/user/68spi ... t%20Spider
http://www.youtube.com/user/Coontache/videos
Estepp14
Re: No fire
Post by Estepp14 »
I have no fire at the coil
bobplyler
Re: No fire
Post by bobplyler »
How are you testing spark?
Have you looked at the points, rotor and cap?
It is most likely the points.
Fi8spider
Re: No fire
Post by Fi8spider »
Did it just conk out or did you find it like this?
Estepp14
Re: No fire
Post by Estepp14 »
It was running fine when I parked it.The car sit around a month went to move it wouldn't start.I now have found a fuse blowed under the dash that comes from the switch.Do you think this is the problem? I can't find fuses. Does anyone know were they sell them and would the blow fuse be the reason I have no fire
AriK
Re: No fire
Post by AriK »
Estepp14 wrote:It was running fine when I parked it.The car sit around a month went to move it wouldn't start.I now have found a fuse blowed under the dash that comes from the switch.Do you think this is the problem? I can't find fuses. Does anyone know were they sell them and would the blow fuse be the reason I have no fire
There's a pink wire led from the ignition switch to the coil. It should be hot when the ignition is on. The same circuit shares with some dash lights. No power from this wire = no fire. An auto parts store may special order these fuses, and while you're at it change all of them, good or not.
TStark
Your car is a: 1975 Spider
Re: No fire
Post by TStark »
Must be something else, i believe ignition and start are not fused.
