Ok I found a do-it yourself inner cable, got it cut and crimped to correct length. I lubed it with silicone spray. I hooked it up to the speedo and tested it with my drill and it works just fine. I ran out of daylight pretty much after that.
Man I miss my old garage!
Now I gotta see if my friend will be doing anything tomorrow evening because the hole in the fabricated plate is the right size, but the opening in the firewall doesn't line up completely of course!!
So I need to take the clutch cable loose once more. Replacing it was pretty close tolerance on the pedal so I need an extra hand anyway. Hopefully by this time tomorrow I'll have a speedo! Does anyone have any routing tips?
Tired Clark
