and that's first 4 gears
2104 is 980kg, according to the book. add 50kg or so for LPG system. engine is a bit lighter than original, gearbox is heavier, i used banded steelies and 205/60/13's so add maybe 20 kilos there... all in all i recon just under 1100kilos.
it was my "mule" car for years. cheap to buy, good acceleration, dirt cheap bumpers, lights and stuff that gets damaged in city driving and boot big enough to fit rear axles, engines etc. also, i was not afraid to experiment on it. that's how i found out that, for example, teflon silent blocks aren't such a good idea and that lower suspension arms need to be re-welded and strenghtened if you plan on stiffening up the suspension.
i got it days after my fiat 132 go badly rear-ended by a guy driving a couple years old ford focus. he was moaning and crying about his car and i was wondering if will ever be able to find a new rear bumper...
how heavy should 1971 spyder with 1608 be? i know that it has much heavier sills, but it has no roof, half the glass less, less interior pieces...
1978 Spider 1800cc engine horsepower?
- aj81spider
Re: 1978 Spider 1800cc engine horsepower?
According to Road and Track in their 1971 article it was 2195 lbs (998 kilos) curb weight.
A.J.
2006 Corvette
2006 Corvette
if it's true, it's a lot for such a small car.
one i'm currently restoring had lost a good portion of that weight to rust. i'll see how much it will weigh in the end
Because convertibles inherently lack stiffness they need a lot of extra metal to try and make up for it.djape1977 wrote:if it's true, it's a lot for such a small car.
So What can I do with my 77 to increase the horsepower to the max? Can my engine be fitted with dual carb and what kind of gains will I get?
This is an old thread, you might be better off starting a new one. Your budget will dictate what mods are best. Yes, you can fit dual carbs to a 1800.
