an even shorter spider
Anything goes (within forum guidelines of course)
this 1980 is at Copart in Georgia
DanD
Re: an even shorter spider
Post by DanD »
I feel like there is some sort of subliminal message here.
not from me, just sad to see another Spider go down
narfire
Post by narfire »
Just chop the front off and weld another on.....if the sub frame was straight I guess
courtenay
Post by courtenay »
narfire wrote:Just chop the front off and weld another on.....if the sub frame was straight I guess
And you know all about that little process - eh, Chris??
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
SoFlaFiat
Post by SoFlaFiat »
Discovery Channel is in negotiations for the new show
"Naramata Chop Shop"
:D
Look out Bernie and Leepu! There's a new chop wizard in town!!
narfire
Post by narfire »
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
Just wondering: What is that red "FIRE" sign on the wall pointing to.
The car looks great. My car appears to have the something like that done as a repair. The is a weld across the car in front of the rear seat.
spiderrey
Post by spiderrey »
A fire sign like that usually points to a fire extinguisher.
narfire
Post by narfire »
spiderrey wrote:A fire sign like that usually points to a fire extinguisher
I think he used to have a large cup of cold Tim Horton's coffee there once upon a time....
Not a bad idea to have a real fire extinguisher there really.
I could have used one once upon a time.... Tacking in a plate over the cracked fire wall at the clutch cable hole. I had put a bunch of wet towels below the spot to protect starter etc. but some sparks still made it to the floor. Finished and took away the towels and noticed a different colour light..... looked under the car and the sparks had ignited a small pile of sawdust (use the stuff to soak up spilled fluids) and I had a nice little camp fire going under the car... :oops:
Funny thing is I did use a cup of Tim's tea to blacken it down before spreading it around and putting it out.
No damage to the car...
