Head gasket help
Re: Head gasket help
you could bend the auxillary shaft. Are you sure all of the gears are tight?
Do you mean pulleys/timing belt? Because i think that stuff was good...So Cal Mark wrote:you could bend the auxillary shaft. Are you sure all of the gears are tight?
Friend of mine, did the same and he bent the valves. And he just got his head rebuild
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
So, this is where I'm at now with my head gasket replacement.
The other half is still inside.
Who knows a handy method for extraction? I tried coaxing it out with a screwjy but i didnt budge.
Im not sure if the shaft damaged anything else but i hear they can punch a hole in the block. I dont think this is the case but i dont know where to look either.
- Your car is a: 1970 128
- seabeelt
- Patron 2019
Embarrassed to say this happened to my son and I right after he got his car and the head gasket blew. Dad forgot to recheck the timing mark on the aux shaft and broke it spinning the engine. Tried fishing it out of the aux shaft hole with one of those magnets on a stick, but only succeeded in pulling it out just far enough to drop it in the oil pan. Sooooo another hour later we fished it out of the oil pan after jacking the motor and dropping the pan just enough to get it out of the pan with the magnet on a stick. Got a replacement for Danny at Fun Imported.
Actually, i have an inline fuel pump installed so the only thing the aux shaft drives should be oil pump.fiatfactory wrote:Your car stopped as the aux shaft drives the fuel pump, and you would have run out of fuel...
Try taking the fuel pump off, and then you might have more luck removing the broken piece.
SteveC
So the piece slid out easily after you got a hold of it with the magnet then?seabeelt wrote:Embarrassed to say this happened to my son and I right after he got his car and the head gasket blew. Dad forgot to recheck the timing mark on the aux shaft and broke it spinning the engine. Tried fishing it out of the aux shaft hole with one of those magnets on a stick, but only succeeded in pulling it out just far enough to drop it in the oil pan. Sooooo another hour later we fished it out of the oil pan after jacking the motor and dropping the pan just enough to get it out of the pan with the magnet on a stick. Got a replacement for Danny at Fun Imported.
For an FI Spider or carb'd Spider with an electric fuel pump, a lot of people just cut the fuel pump lobe off and plug the end with a threaded plug. What happened is that the lobe hit the #4 connecting rod. Aux shaft timing does not matter with that modification. You are lucky... with enough force that interference will crack the side of the block.
MikeR ('77)
MikeR ('77)
- seabeelt
- Patron 2019
Yes, the magnet was strong enough to pull it part way. It looks like you have your oil pan off already, so you could just push it toward the rear and it should fall out.
R/
R/
Doesn't cutting the Aux Shaft lobe off effect part and thereby engine balance?
- Your car is a: 1982 Spider
Probably not. That lobe is immediately behind the rear journal being held snugly in the bearing. I didn't notice any kind of counterweight when I was cutting off the lobe on Monday. Drilled tapped and plugged oil hole with short bolt (with locktite). If anything, it would seem the shaft should run better without an off-center lobe hanging off the end of it. Besides, in an engine using this for the mechanical fuel pump there is the pump (arm or plunger[never saw one] ) pressure against it. No?
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
Sounds like it is possible taking the lobe off would actually improve balance.
