Weber 32 ADFA vacuum ports
bcs163
Post by bcs163 »
Hello,
I seem to be missing a vacuum line port off of my carburetor. I was tracking down vacuum lines with a diagram and found a port that didn't exist on my carb.
Bottom left
Then I noticed that the vacuum port above it was silver instead of brass colored - and it wiggled out with a little effort
Is there a place to get the vacuum line inserts like these?
I couldn't find anything (maybe I'm using the wrong search terms) - starting to think I might have to use some fuel/brake line tubing as the PO did.
'76 Fiat 124 Spider - Padrona
bcs163
Re: Weber 32 ADFA vacuum ports
Post by bcs163 »
So, after a night's sleep and scanning several carburetor parts sites - I think I found the close enough answer.
They don't make a brass insert like this - they only have ones designed to be threaded into the carb body, like this:
So - why not get one with the right hose size, and cut off the threaded part
Thoughts?
