I have come across a few things that i can't remember where they go. Do any of you know what they are and where they go? i'm not even sure if it's all fiat stuff. i may have mixed some stuff in my boxes on accident
thanks
Anyone know what these are?
- Your car is a: 79 spider
Re: Anyone know what these are?
#2....fire wall grommet for throttle cable??!!
The others don't look familiar to me
Warren
Warren
Thanks Warren....wizard124 wrote:#2....fire wall grommet for throttle cable??!!
Warren
If that's the only parts you were left over with after your build i bow to you, sir
- FiatMac
#1- Stops in the seat slider tracks to limit backward travel?
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
Thank you. Two down... Three to goFiatMac wrote:#1- Stops in the seat slider tracks to limit backward travel?
Yes, number 1 does bolt to the set rail, but I don't remember exactly how. Number 2 is the firewall grommet and bushing for the early throttle linkage.
Number 5 is a spacer that goes where the steering column mount bolts the cross brace.
Number 4 goes on the 78-on reverse light switch to hold the wires.
Thanks crabs.vandor wrote:Yes, number 1 does bolt to the set rail, but I don't remember exactly how. Number 2 is the firewall grommet and bushing for the early throttle linkage.
Number 5 is a spacer that goes where the steering column mount bolts the cross race.
Dang auto correct.... Sorry csaba, that was supposed to say:
Thanks csaba....
Not done putting it together yet.... These are just the things I didn't know what to do with.... I'll have a lot of leftovers. A have two buckets of nuts and bolts from 8 rusty spider I tore down...AriK wrote:If that's the only parts you were left over with after your build i bow to you, sir
Hope you resume your project soon, work out all the ins and outs and finally get behind the wheeljuvius wrote:Not done putting it together yet.... These are just the things I didn't know what to do with.... I'll have a lot of leftovers. A have two buckets of nuts and bolts from 8 rusty spider I tore down...AriK wrote:If that's the only parts you were left over with after your build i bow to you, sir
- Your car is a: 1981 2000 Spider
# 5 may be a door hinge back support, and # 4 a hose connector.
Always looking for curves under blue skies!
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
