Wiper bearing service
Robertglab
Post by Robertglab »
Has anyone pulled apart and cleaned/ serviced the wiper arm joints, I can't seem to figure out how to open them up to try. I have the whole system torn down on the workbench, I just can't get into where I thing needs the most love. Any thoughts?
Rob
wizard124
Re: Wiper bearing service
Post by wizard124 »
I just cleaned the joints as best I could with WD40. Then lubed them with lithium grease and worked the grease in as best I could.
Probably not optimal but I didn't break anything either :D
Robertglab
I tried to pull them apart, absolutely destroyed the thing, but I found a replacment carrage for 79$. I knew it might expensive when I resorted to the hammer and vice. http://www.midwest-bayless.com/storefro ... =302475999
Thanks anyway,
Rob
fredguaz
Post by fredguaz »
Some guys drill a hole into the bearing to clean and lube, then silicone the hole shut.
Seems to work. Do a search.
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
131
Post by 131 »
Motorcycle chainlube is available in a spray can. Using the small tube in the nozzle the lubricant can be directed to anywhere you want it, the solvent evaporates and you're left with a sticky lubricant in the bits you can't reach.
Mick.
