Clutch fork / Throwout arm assembly
V12StealthHunter
Your car is a: 1971 Fiat 124 Spider
Post by V12StealthHunter »
I'm changing the clutch and I was about to change the throwout bearing when I noticed that the Haynes manual says the clutch fork is held onto the stretcher yoke (that ball/stud thing?) using a split pin (page 83). Mine looks like its just pressed onto that stud. Am I missing something?
Also, is anything meant to be lubed up when changing the throwout bearing?
Apologies if this isn't the right place for transmission questions.
Thanks.
1971 Fiat 124 Sport Spider
Re: Clutch fork / Throwout arm assembly
I lube contact points on the arm
