I’m new to the Fiat Spider world, but not the automotive. I need to change out an 82 Spider radiator due to leakage and after searching (on and off line) around it seems like it’s a semi-normal thing for these cars. That being said, I found some information converting to an aluminum Volvo 240 radiator, it seem straight forward, but I just wanted to hear from others if they have done this swap, if they are happy with it, and if they had any pointers they could share.
I’ve found the following post and write up’s
http://mirafiori.com/faq/content/volvor ... adconv.htm
http://www.fiatspider.com/f08/viewtopic ... 30&t=14931
Here’s the part list I’ve compiled, I’m only putting parts that relate directly to the swap on it. If anyone see’s anything missing please let me know.
Parts are from a Volvo 240 unless otherwise specified
- Part - Link
- Radiator - http://www.rockauto.com/catalog/raframe ... um=8010083
- Fan Temp Switch - http://www.rockauto.com/catalog/raframe ... um=1580964
- Electric Fan - http://www.autozone.com/autozone/parts/ ... 9587_7523_
- Lower Hose - http://www.autozone.com/autozone/parts/ ... 4_0_10495_
- Radiator Cap (Black) - http://www.rockauto.com/catalog/raframe ... tnum=10245
- Coolant Expansion Tank - http://www.rockauto.com/catalog/raframe ... um=9122997
- Coolant Recovery Tank Hose - http://www.rockauto.com/catalog/raframe ... um=9141262
- 1/2” aluminum c-chanel stock - hardware store
- Radiator upper brackets - ebay
- Spider hose rad to engine - http://www.rockauto.com/catalog/raframe ... tnum=70687
- Spider hose engine to thermo - http://www.rockauto.com/catalog/raframe ... tnum=61080
- Hose clamps, relay, wire - autoparts store
-Dan
