No power
fiat218
No power
Post by fiat218 »
Ok, let me see if I can explain, 2.0 engine. When I got it , it would haul ass between 3000 rpms and up
Now all I have done was mess with the duals 40 idfs
Changed the jets, and setting the idle screw and the mixture screws
It runs smooth,no hesitation, at low speed or high, but it just seems to have no get up and go like it did,
Nothing been changed as far as the timing from the start , so I know that is not is, it has something to do with the carbs. What is it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
vandor
Re: No power
Post by vandor »
What did you change?
What was the old and the new jetting?
sptcoupe
Re: No power
Post by sptcoupe »
And why did you change the jets, etc? Was it not running well in some other way?
fiat218
Re: No power
Post by fiat218 »
vandor wrote:What did you change?
I'd have to look. Seems that maybe the problem, I
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: No power
Post by fiat218 »
It was missing , so I was thinking it was the jets at that time, but it was because of other things going on, but it runs great now, just no power
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: No power
Post by fiat218 »
So I should switch back to the old jets?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
seabeelt
Patron 2019
Patron 2019
Re: No power
Post by seabeelt »
I would go back to the old setup. More than likely one of the jets had some bit of dirt or crud in there and got dislodged when you changed things. This happens every once in a while on my setup. I just pull the jets, flush with carb cleaner and reinstall.
fiat218
Re: No power
Post by fiat218 »
Ok, thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: No power
Post by fiat218 »
if one mixture screw dont make a differnce,in or out , what would that be caused from
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
bradartigue
Re: No power
Post by bradartigue »
Idle jet is too large. at least that is typical of the "mixture screw does nothing" problem. typical diagnosis is to seat all of them, the engine should die, but when you turn them (or one) out it is immediately too rich and nonadjustable.
But then again, running IDFs is like buying frustration. Especially on anything bigger than the 1608. They are going to run like crap 99% of the time, and then you convince yourself its running great and you tell others how great they are. This is what we call the acceptance phase. At some point down the line you ride in someone's car without IDFs, say a fuel injected Spider or one with a big ADF, and you put the IDFs on ebay. We call this the freedom phase.
fiat218
Re: No power
Post by fiat218 »
I was going to get a single carb, I'm no mechanic and tired of playing with them-so I might as we'll settle for a bigger single carb, and what carb would fit this 2.0 the best
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
bradartigue
Re: No power
fiat218 wrote:I was going to get a single carb, I'm no mechanic and tired of playing with them-so I might as we'll settle for a bigger single carb, and what carb would fit this 2.0 the best
1800 manifold and a 34ADF. Always the best combo. If you can find one get a 36ADL. Basically the same thing but bigger. Both work great with stock everything else.
fiat218
Re: No power
Post by fiat218 »
Ok thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
stpher
Your car is a: 1982 F I spider
Re: No power
Post by stpher »
Hi,
I have an 1800 intake that has been blasted and cleared for sale, looks as good as new. My e mail is alfaspider1969@gmail.com and I can send you some pictures of it.
Single plane with the EGR holes bolocked off
Thanks, Rick
fiat218
Re: No power
Post by fiat218 »
stpher wrote:Hi,
Thanks, Rick
Pm sent
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
