oil pressure
oil pressure
78 fiat 124--sitting at red light-oil pressure light came on-drove one mile to home. I would hope it is sending unit--any one had this problem and can the mechanical oil pump just quit
Re: oil pressure
Did the car overheat or behave oddly? Ran ok that last mile? Revving normally? No burning smells?
- 81SPIDERMATT
Re: oil pressure
or I could be just low on oil
Re: oil pressure
no not low on oil-just changed-not running hot--ran home ok--will try to check wires on sending units if I can find them
- kilrwail
Re: oil pressure
I had the same problem recently but knew the pressure was OK because I have a mechanical pressure gauge. Finally diagnosed the cause to be a blockage in the oil passage within the filter housing, that leads to the sending unit for the light. Cleaned it out with a piece of coat hanger wire and compressed air and it's all good now. I've no idea what caused the blockage - something that didn't make it into the filter.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: oil pressure
changed the sending unit and it fixed it--sending unit awful dirty in the vent hole
Re: oil pressure
That hole is actually a treaded jet and can be removed and cleaned.
