Transmission Interchange?
Looking for a transmission for my 71 1608 and found an 82 with low miles, near me and cheap. Will this work?
72 124 spi bought new - the carcass is buried in the backyard
71 spi swapped drivetrain from 72 - sold in 88
71 coupe - traded for new Lancia
77 Lancia Beta Saloon
71 1608 spider - impulse buy - project
- Your car is a: 1975 Spider
Re: Transmission Interchange?
yes!
1. the speedometer will not be accurate, as the gearing on the speedo drive will be different.
2. if your car had a 1438 in it, the bellhousing will be different. can be a direct bolt on swap
3. the shifter, if yours is original, it is a pull up for reverse, the 82 will be a push down, you can interchange the complete assemblies with no issue, or use the one that came with the new trans.
son has 78 spider
son has 78 spider
Perfect, Thanks Beek.
