mdrburchette wrote:I'm afraid I disagree. Although the 82 is fuel injected, the early ones are more classic. Why else would so many people spend so much time and money to make their later models look like the early ones? Really, you should look for the best example and not worry too much about what year it is. They all have their good points and bad (although I can't think of any bad for a 72 ). Here are a few things you need to look for when buying:
Rust. Check the outside shell for any paint bubbling. Rust starts from the inside and goes out so bubbles means rust through damage. Also get under the car and use a screwdriver to test the floor pans. Also check the shock towers and crossmember to make sure they're solid.
Door hinges. Especially in the later model cars, open the doors and check the upper and lower hinge mount points on the door itself. If they are cracked, they're a bear to have repaired.
seatback frame. Especially on later models, the driver's side seatback can become bent from people leaning over and pulling the top up while sitting in the car. The fix isn't so bad if you can use a welder.
Electrical. Make sure everything works on the car. Nothing's more of a pain than trying to trace and repair wiring that someone else has tried to repair.
Transmission. Make sure the transmission operates smoothly and doesn't jump out of gear or grind. They can get expensive to repair.
Does anyone else have more to add?
I would also look for gear whine or other issues in the rear differential , particularly on '79 and up models as they used a different design. Pinion seals on the front of the diff often leak leading to low fluid and premature failure. It is also imperative that you replace the timing belt immediately after purchasing the car unless there is documented evidence that it has been done within the last several years or 30,000 miles. The good news is that many parts for Spiders run significantly cheaper than most other cars, even with the devaluation of the dollar against the euro. Good luck!
Oh, and I almost forgot -- 1982 is the best year to own
