1975 124 Intake Manifold Sensors Needed Or Not
Flyboytha1
Post by Flyboytha1 »
Hello guy's i've been having really good luck with super fast replys with great help & a great site for info:
Are these sensor being use in other 75" 124 spiders i'm in california but don't need smog cause it tops out at 1975 and lowwer :D
Anyways so what are the 2 bottom sensor used for and there's also one on top of the manifold if not need can i leave them be and not have to worry?
Also what is this 2 way brass tube there to the right there use for or go to or can it be simply plugged?
Thanks Much Again Guys!
The 2 sensors in photo #1
Center Sensor in photo.
2 way Brass "T" off the the top right side?
tartan18
Re: 1975 124 Intake Manifold Sensors Needed Or Not
Post by tartan18 »
On my 1975 I just removed or capped off the sensors as these are for the emission control system. The brass T is a vacuum port. One side connects to the brake booster. You can cap the other side off. Most auto parts stores carry a package of caps in various sizes. Depending on what carburetor you have you can also plug the others off or use one vacuum port for your carb's advance.
Jim MacKenzie
1975 Fiat Spider
Flyboytha1
Great thanks much again 8)
