Yeah seems like idle just over a 1000RPM works for me. I need to get a tach, so I know what it really is verses the tach in the instrument panel.I also took the temporary measure of increasing the throttle plate set point to artificially raise the idle, then shut down the idle screw completely,
Weird because I know I had it working perfect until I messed with the throttle stop and idle screw and subsequently the TPS. So I am going go try more tweaking. The idle screw o-ring is on my list too if you find one.
BTW, you probably know you don't need to pull the head to do the injector on-rings, but just in case, I thought I would mention it.
